Message 11 of 15
Re: NETGEAR Nighthawk X6 R8000 WiFi Cable & Fibre Router - AC 3200, Tri-band
Thanks, I was just about to ask that very question
Message 12 of 15
Got the new router, wow the wifi is 100% better!! Does this look normal for line?Archer-VR2100 (9).png
Message 13 of 15
Yes, that looks fine.  You may see a slight improvement in connection speed after a few weeks, but the noise margin of 6.3dB, makes for a very stable connection. WiFi coverage should be very good.
That is the TP Link  VR2100, just to bake it clear to other forum users.
Message 14 of 15
Yes the  TP Link  VR2100  amazing wifi coverage full bars in bedrooms now
Message 15 of 15
Its the external aerials that make a difference. The home hubs have internal aerials which are not very efficient, but it looks better in a domestic setting, so some sacrifices have to be made.
