Message 1 of 7
NOW TV Channels
I have just purchased a Now tv pass, but can't see the listed channels in my bt tv guide and can only access them through the app. This means I can't record programmes or see when the programmes I want to watch are on.
Are the channels only available through the app or should I be able to access them through the tv guide as well?
6 REPLIES 6
Message 2 of 7
Re: NOW TV Channels
Did you buy the pass through BT or direct from NowTV?
Message 3 of 7
Re: NOW TV Channels
I bought the pass through BT
Message 4 of 7
Re: NOW TV Channels
Try doing a rescan of channels on your Youview box. Channels may show up after that.
Darren
Message 5 of 7
Re: NOW TV Channels
Thank you, but I have already tried this and it hasn't worked, so far
Message 6 of 7
Re: NOW TV Channels
Probably tried already but have you attempted a software update in the settings?
I had this happen before and although technically I was on the latest firmware, the update checking did force a restart and the NowTV channels were then visible.
Message 7 of 7
Re: NOW TV Channels
Thank you, I have tried this and unfortunately it didn't work
