Message 1 of 2
Need a DLM reset on banded connection
I recently discovered a fault with a 3rd party router cable that had a slightly faulty plug which was too short and didn't hold firmly in the master BT socket, it caused my router to disconnect when the cable was touched or moved. I am now stuck permanently on a 9dB connection which I believe is way above the default BT 3dB profile. I have done a noise test on the line and its quiet as a mouse.
I have asked customer services to reset the DLM but get the ubiquitous "you're within contracted speeds" answer.
Can an admin request a DLM reset please.
Connection is a FTTC superfast line.
This is a list of your BT Smart Hub settings and current statistics.
Product code:Smart Hub 2
Serial number:+091298+2045002218
Firmware version:v0.26.03.01286-BT
Firmware updated:Wed Apr 14 07:15:51 2021
Board version:R01
GUI version:1.74 12_11_2020
DSL uptime:26 days,18 Hours50 Mins16 Secs
Data rate:16.996 Mbps / 54.999 Mbps
Maximum data rate:17.220 Mbps / 65.383 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:5.8 / 8.9
Line attenuation:9.4 / 19.4
Signal attenuation:9.4 / 21.2
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:32.8 GB Uploaded / 172.6 GB Downloaded
Broadband username:[email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:BT-TQASQF
2.4 GHz wireless channel:Smart (Channel1)
5 GHz wireless network name:BT-TQASQF
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:E4:75:DC:F4:02:E1
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
1 REPLY 1
Message 2 of 2
Re: Need a DLM reset on banded connection
Hi @sjessel welcome to the community and thanks for posting, it looks like your profile is banded to 55Mb. I'll send you a private message so you can send over your details to the moderation team and we'll be happy to help.
You'll get the private message by clicking on the envelope in the top right of the community.
Neil
