Message 11 of 12
Re: Need to replace Broadband cable supply with wifi Halo2.
@Frosty75
Just a thought, if BT cannot provide you with a reliable and working service (and you may have to give them a few tries at making it work) you may (and I stress MAY) be able to remove yourself from the contract in time.
It's worth trying to get the service working.  Do you know what speeds the line is supposed to give you?
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 12 of 12
CIT80 .
As I have had lots of trouble with my telephone line, and even Halo 2 was little better than Halo , I thought it would be a good idea to go 100% wifi with BT new 4G Hub. Ordered a 4G hub. Arrived today. But hardly any improvement going from ca. 17Mbps to 23Mbps. Contacted BT , Ring back promised, none received.
I PROBABLY WILL MAKE USE OF 14DAY COOLING OFF PERIOD.
FROSTY75
