Anonymous
Not applicable
Message 1 of 4
Need to replace the main power supply.
Hello,
I have a DTR 2100 Box and need to replace the main power supply as the power supply has had it.
Can someone tell me were I can buy a replacement power supply.
thanks
3 REPLIES 3
Message 2 of 4
Re: Need to replace the main power supply.
I believe you can get them free of charge from BT if you're in contract. If you're not in contract and don't plan to enter into one then try ebay and Amazon
Anonymous
Not applicable
Message 3 of 4
Hello
thanks for getting back to me, have tried Amazon but no good, can you tell me what I am looking for ?
thanks
Message 4 of 4
@Anonymous
If you are not in a contract, then Discomm can supply them, as they are authorised BT Spares supplier.
Look under the power supplies category.
