Message 1 of 4
New BT Fibre
Hi, I'm Considering getting the BT Full Fiber 900 Connection (as it is available in my area)
But I had two questions about it that I can't find answers for,
the first is that I have a Rather Expensive Wifi Router that has better specs than the smart hub 2 are you able to put it in Modem/Bridge mode and negate the need for it?
The second being Can you still do that if you go the that Hybrid Connect thing.
3 REPLIES 3
Message 2 of 4
Re: New BT Fibre
The fibre ONT is the modem, you only need a PPPoE capable router to connect. The BT hub is not required.
Hybrid will only work with the BT hub
Message 3 of 4
Re: New BT Fibre
If you get FTTP the you may be changed to Digital Voice using the SH2 as a base station with VOIP   you need the hub to get a landline connection but if you do not use your landline phone then not a problem
Message 4 of 4
Re: New BT Fibre
@imjolly  Customers will only be changed to digital voice if they accept it, otherwise the copper line will eventually be ceased giving them time to get a decent VoIP service that doesn't depend on ISP supplied equipment.
Personally if I needed a home phone rather than my moble I'd get a VoIP service now and port my number to it. I am not au fait with being locked into using ISP supplied equipment except for a modem if necessary.
