Message 1 of 18
Why is my Upload so low?
Hi All,
Wondering if you wonderful people can help. When I was on EE I was getting 20 meg upload, I am on BT and now its only 9meg if I am lucky. I would love to know if I am banded? Or an I on the right profile? Did a BT speedtest and it came back with 50meg? Something doesnt quite feel right?
Here are my stats.
Product name:
BT Hub 6A
Serial number:
+084318+NQ81186241
Firmware version:
SG4B1000E020
Firmware updated:
20-Dec-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
0 Days, 3 Hours 47 Minutes 35 Seconds
Data rate:
15.00 Mbps / 55.00 Mbps
Maximum data rate:
21098 / 65383
Noise margin:
10.1 dB / 8.7 dB
Line attenuation:
27.3 dB
Signal attenuation:
19.8 dB / 27.3 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
522 MB Uploaded / 20 GB Downloaded
Broadband username:
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-HFR9
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-HFR9
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
AC:3B:77:15:24:DD
Software variant:
Boot loader:
9.2.0
17 REPLIES 17
Message 2 of 18
Re: Why is my Upload so low?
Can you try the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Your connections time is only 3hrs is that due to hub dropping connection or manual reset?
Your have a 55/15mb connection so I assume you are on fibre 2 package
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 18
I had the same issue now whether they'll do anything is another matter as upload isn't covered. In my case the support guy I spoke to could see a lot of errors plus resyncing  going on so logged the call.
They managed to get the speed up to spec by resetting the dslam but the line was unstable so they had to slap on interleave which meant I lost a bit of the max speed but the line stayed up plus I still had full speed on the uplink.
In mine case the phone was perfect zippo noise.
Message 4 of 18
It’s so odd.. I’m just gonna leave it and see if it picks up.
Message 5 of 18
Perhaps @imjolly will ask one of the mods to take a look for you.
Message 6 of 18
I’d appreciate that @pippincp
Message 7 of 18
Hi @samtheaspie, would you be able to confirm if you are on a Fibre 2 package?
cheers
John
Message 8 of 18
@JohnC2
Message 9 of 18
Hi @samtheaspie, thanks for confirming that for me. I've sent you a Private Message so you can get in touch with the Mod team and we'll be happy to help you with this.
cheers
John
Message 10 of 18
@JohnC2 @Done that thank you
