Message 21 of 35
Re: Best Router solution with Smart Hub 2
Why do you need to start another thread? All the answers have been given on your other thread.
To recap. Unless you want BT Digital Voice, your existing setup can just be connected directly to the ONT with minor configuration changes on your Asus device.
If you do want DV, then you can still use your existing setup with the changes detailed in your other thread.
Message 22 of 35
A simpler solution would be to continue to use the SH2 but turn off either the 2.4 or 5GHz then connect a Wi-Fi repeater, in access point mode, to the SH2 by ethernet cable to provide the band you disabled on the SH2.
Message 23 of 35
As someone who has had a SH2 since before it was launched, and a house full of smart devices* that "require that 2.4 and 5Ghz channels are separated" ... I can say that I've never had a single device that actually needed the separation. Some smart device apps show warnings during setup, but they still work fine.
*Light switches, bulbs, cameras, plugs, etc
Message 24 of 35
The OP started all this by asking if he could use his existing setup, to which the answer is yes, unless Digital Voice was required. A tweaked solution keeping existing setup plus hub for DV was supplied. I'm not sure what he is actually looking for with this thread.  Any solution is going to be less than perfect but will be stable and work.
Message 25 of 35
Re: 2.4GHZ and 5GHZ Bands BT Smart Hub 2
Moving to BT FTTP 300mb connection shortly. Need BT hub for digital phone purposes.
If I connect Asus RT86U Router to it as an Access Point and disable the WIFI on the BT Smart Hub 2, will I be able to use the 2.4 and 5ghz via the Asus?
Will I need a different subset for the AP for this?
I need the BT Hub ethernet ports for my PC and a switch.
Message 26 of 35
Re: New FTTP order - will existing setup work?
@licquorice
If I connect Asus RT86U Router to BT Hub as an Access Point and disable the WIFI on the BT Smart Hub 2, will I be able to use the 2.4 and 5ghz via the Asus?
I need the BT Hub ethernet ports for my PC and a switch. Needless to say, this will give me digital voice.
Message 27 of 35
@Les-Gibson
In that case, would it not be better to turn both off and use the Router for these?
Message 28 of 35
Right, let's start again. It would appear that currently the only WiFi device you have is the Asus. In which case why don't you simply remove the Asus and replace it with the BT hub. You can still connect your PC and switches to it as with the Asus and use the hub WiFi.
Message 29 of 35
@wizzard
You could do if you wanted all of your Wi-Fi traffic to connect to the extender, personally I wouldn't want that which is why I didn't suggest it but the choice is yours
Message 30 of 35
@licquorice
Was my initial thought of using BT hub only. However, this forum has various posts that state that there are issues with the 2.4 and 5ghz devices in talking to each other. It seems BT have tried to fix this but as of today, not managed it.
