Message 11 of 22
Re: New Norton software
Hi I had the same problem and I'm pleased to say that this approach worked for me. As noted there was 1 file containing the name mcafee in each of the two folders. Thanks to the originator of this fix.
Message 12 of 22
As advised, downloaded new Norton Software... NOT happy. I had plenty of security from Windows defender. Now everything going haywire... How do I disable it?
Message 13 of 22
Uninstall it in the same way as you would any other program.
See Norton's link
Uninstall your Norton device security product on Windows
Message 14 of 22
Tried that but it is STILL there in the BT account, though the Windows Security seems in charge. This is getting silly... especially when I see the amount the bill will be going up!
Message 15 of 22
I have had exactly the same problem with my Mac.  I did what you did and removed the hidden files, but the Norton software will still not load.  There must still be another hidden file somewhere.
Message 16 of 22
I'll keep looking!
Message 17 of 22
Hi regarding looking for files. You probably realist this but they also need to be permanently deleted from the trash. Bst of luck.
Message 18 of 22
I have finally located the rogue file in Launch Demons in my Mac library.  It was com.mcafee.cspd.plist.  The Norton software loaded successfully after removing this one last file.
Message 19 of 22
Yes, but thanks.
Message 20 of 22
Last time I left Mcaffe I found a small program on Mcaffe site that removes all trace of the program
trumble
