Message 81 of 86
Re: New Smarthub2 and WDMYCloud connectivity
@newja
This is a long thread and I may have missed why the SH2 can't access the SSD, if so apologies, but if the SSD is a 2.5 inch internal drive you could mount it in a cheap USB enclosure to plug it into the SH2.
EDIT - I see TimCurtis has covered this
Message 82 of 86
@TimCurtis wrote:
@newja
It's quite possible that the SH2 USB port doesn't supply enough power to support an SSD drive, have you a flash drive you could try as that requires a lot less power?
It powers my Toshiba 2Tb SSD drive ok.
Message 83 of 86
If only we did know why it will not read it!  I certainly would not be dismounting a new SSD to test anything out!  I shall, however, be trying a flash drive after Ive done dinner 🙂
Message 84 of 86
...which was a "no"!
Message 85 of 86
Just as a total long shot, it shouldn't have any effect, but make sure you have turned off Smart Setup on the hub.
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
Message 86 of 86
@licquorice indeed, that was an early action! Thanks 🙂
