Message 1 of 6
Force public IP address change
Hi,
We are having some issues with reoccurring dropouts and we suspect an attempted denial-of-service (DDoS) attack. Our set up is Dreytek Vigor 130 and Ubiquity  EdgeRouter x. The connection is dropping out every 20mins for a short period and has started at the same time the last couple of days. We are monitoring the connection to see if it's a true DDoS attack but would like to force a public IP address change.
The question is – How do we force a public IP change?
Cheers,
IDWBP (I don't want to be pinged)
5 REPLIES 5
Message 2 of 6
Re: Force public IP address change
Turn off the router for a bit (like 30mins or above), even though the assigning of the IP address is dynamic it needs to be released
Message 3 of 6
Are you a BT Business account user?
Why do you suspect a DDoS attack rather than a possible electrical interference or other problem?
Message 4 of 6
Because we use the connection 24/7 and have never experienced this type of activity before. Also nothing has changed in our set up or with any other device in the install location.
Message 5 of 6
Virtually everyone leaves their connection on 24/7. Do the router logs show a DDOS attack?
Nothing needs to have changed for a fault to have developed, they occur at random!
Message 6 of 6
You never answered the question "Are you a BT Business account user"
