Message 11 of 71
Re: No Dolby Atmos on BT Sport App (Shield TV/Fire Stick)
@DarrenDev
Saturday game - no problems at all with Atmos on the Shield TV, worked first time.  It is definitely more successful recently than previously when it never worked.
Message 12 of 71
Hi @DarrenDev
More inconsistencies with the Saturday game.  Cannot get Atmos at all via the Shield TV despite several restarts.  Just plain 2.0. Switched over to Fire TV 4k and Atmos works fine with that.  I haven't changed anything at all in my setup, it just seems to work so inconsistently.
Message 13 of 71
My Sony TV (Android BT Sport App) plays 4K broadcasts fine but the sound is is Stereo PCM rather than DD2.0 or DD5.1
Is there an issue with the App? (Netflix and Prime video apps play DD5.1 fine).
thanks,
nick
Message 14 of 71
What event were you watching @njcollins ? Was it on BT Sport Ultimate?
Message 15 of 71
Hi Darren, I can’t remember now. But it was definitely BT Sport Ultimate as it was in 4K. Many thanks Nick
Message 16 of 71
We're currently working on a way to get enhanced logging from Android TV devices, but it's not quite ready yet. In the meantime, I'm afraid we don't currently have any way of knowing why devices sometimes fail to report their support for multi-channel audio.
The only thing I can suggest at this point is rebooting the TV when it occurs - it seems to be that a few uses of the BT Sport app is enough to stop the TV from working correctly, but a reboot appears to clear it.
Message 17 of 71
Ok thanks. Will try next time I see some 4K broadcasts on BT Ultimate.
Message 18 of 71
Hi new season started and was hoping this would be fixed but still no joy. Can you advise if this is still being looked at. Using bt app on Philips  55OLED805
Message 19 of 71
Yes same problem here still.  @DarrenDev please advise if there is any further info or logs that would help figure this out, thanks.
Message 20 of 71
The only issue we're working on at the moment is that the device sometimes thinks it's no-longer capable of multi channel audio.  Rebooting the device always fixes it, so I would recommend you try this first.
If you're still not getting Atmos then that's a different issue which needs separate investigation.
