Message 11 of 17
Re: No Fibre for me...?
I’m guessing that this is my problem...😞
There is no data available for this number. This could be either because it is not a BT line or it is a new BT number that has just been provided. Most new numbers will appear on the checker 24 hours after BT has installed the line
Message 12 of 17
it is because you are with SKY. that is why I asked you to use your address and post results
Message 13 of 17
Dslchecker doesn't work with my phone number, here’s the results from my address.
Message 14 of 17
that's confirms there is no fibre available to you
Message 15 of 17
Sorry, I’m being a bit thick...!
heres my next door but one neighbours results.
Message 16 of 17
Then try phoning BT FTTP TEAM and see what the say. 08005874787
Message 17 of 17
Ideal, thank you For your time and help. I’ll give them a call.
