Message 11 of 15
Re: No subscription channels after connecting mini router
Yes, that is exactly what I have - long cable from hub to mini router, short cable from mini router to youview box.
Your solutiion with the TP-Link SG105 seems ideal, thanks for your help, you have been very patient with me!
Message 12 of 15
@3billy3
Just to try & confirm that if the long cable goes directly into the Youview box BT Sport works. Yes is the answer we need.
Message 13 of 15
Yes, BT sport definitely works with long cable directly into youview box
Message 14 of 15
Then you should be good to go.
Message 15 of 15
Thanks again for the help
