Message 11 of 15
Re: Not Getting Guaranteed Minimum Speed
@imjolly
Thanks - have tried all the things you suggest and phone line sounds clean....
No idea why line dropped two days ago, but I have noticed that it has done this around 2am on 2 or 3 occasions - I assumed that it was BT doing some sort of "line reboot" in the early hours
Download as follows:
Telephone Number XXXXX-XXXXXX on Exchange BYFIELD is served by Cabinet 4
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date Left in JumperHigh Low High Low        VDSL Range A (Clean)
VDSL Range B (Impacted)
8060201954.9AvailableAvailable--
8057.52017.650.4AvailableAvailable--
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33030--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in JumperWBC ADSL 2+ADSL MaxWBC Fixed RateFixed Rate
Up to 1--1 to 3AvailableAvailableYes
Up to 0.75--0.75 to 2.5AvailableAvailable--
0.5----AvailableAvailableYes
0.5----Available----
Observed Speeds VDSLMax Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
43.99
7.03
2020-05-28
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Premise Environment StatusBridge TapVRINTE FacePlateLast Test Date
N
N
N
11-06-2020
Message 12 of 15
The drops in connection are not caused by openreach doing any line reboot and could be some interference locally
are you connected direct to the master socket? is it a filtered master?
have you tried connecting to test socket with filter to see if that improves your connection speed or initially your attainable speed
Message 13 of 15
@imjolly
Yes - I've done all that - router is on master socket - no other devices connected (not even a phone normally!) and I have tried directly into test socket....this has worked faultlessly for the last 2.5 years - it's only the last 6 months or so it has gradually degraded from 60Mb/s dow to as low as 28Mb/s (currently around 40Mb/s) but trying to get BT to investigate is proving difficult!
(I've worked in IT for 25 years, so I probably6 know just enough to be dangerous!!)
Message 14 of 15
if you done all that and not even the attainable speed improved then need engineer visit
Message 15 of 15
See link about the BT Stay Fast Guarantee and when they would honour it.
https://www.bt.com/help/broadband/what-is-bt-s-stay-fast-guarantee-
See this link and sub links about dates when you ordered your broadband.
https://www.bt.com/help/broadband/learn-about-broadband/broadband-speed/i-m-not-getting-the-expected...
