Message 1 of 4
Not getting guarantee
I am not getting the guarantee. Not even close. Supposed to be 28 Mbps and currently getting around 4. Been like this for a few weeks. Here at the stats:
Any help would be appreciated.
Product name:
BT Hub 6A
Serial number:
+084319+NQ65096923
Firmware version:
SG4B1000E020
Firmware updated:
10-Mar-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
0 Days, 0 Hours 54 Minutes 25 Seconds
Data rate:
4.30 Mbps / 10.00 Mbps
Maximum data rate:
4876 / 22118
Noise margin:
5.8 dB / 15.3 dB
Line attenuation:
40.1 dB
Signal attenuation:
42 dB / 40.1 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
224 MB Uploaded / 3 GB Downloaded
Broadband username:
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-3ZH5
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-3ZH5-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:76:21:F7
3 REPLIES 3
Message 2 of 4
Re: Not getting guarantee
Are you using the test socket with a filter to see if that improves your connection speed or at least improves your attainable speed
try quiet line test. Dial 17070 option 2 should be silent and best done with corded phone
Message 3 of 4
Have taken the faceplates off the 3 sockets in the house but no test socket. I don’t have a dial tone on the phone so the quiet line test doesn’t work. I have some speed tests saved on my phone and the in mid March we were getting around 30 Mbps which is above the guarantee.
Message 4 of 4
Report no dial tone on your line, it looks like there's a disconnect somewhere. Broadband will work with only one wire connected albeit slowly.
