Message 1 of 11
Outgoing e-mail on Android stopped working
Hi
My BT outgoing e-mail on my Android has suddenly stopped working. I don't get any error message and I can see the mail in the send folder. I've checked incoming and outgoing settings, deleted mail client and reinstalled to no effect. Outgoing e-mail on my laptop works fine. Can anyone advise please.
10 REPLIES 10
Message 2 of 11
Re: Outgoing e-mail on Android stopped working
Are you a BT Broadband customer or paying for your email through a BT Premium email account?
Message 3 of 11
Hi
Message 4 of 11
Which email app are you using?
Do you have it set up as an IMAP or POP3 account?
Have you confirmed the settings, including the SPA setting?
What are the settings for outgoing and incoming BT Email servers? | BT Help
Message 5 of 11
Hi
Yes, think they are correct
IMAP
Incoming server mail.btinternet.com
Security Type SSL
Port 993
Outgoing server mail.btinternet.com
Security Type SSL
Port 465
Require authentication to send e-mail - On
e-mail address and password
Tx
Message 6 of 11
You may have an email "jammed" that is blocking your emails from sending. Have you tried clearing out any emails that you have tried to send since the problem started. ie going back to your last good known sent email. Do this on your email client and by logging onto your email account with a web browser (webmail).
Message 7 of 11
Hi
Tx. I have done that and deleted e-mail account and re-installed after a phone restart to see if the helped but still no luck on outgoing e-mails.
Message 8 of 11
Sorry missed the e-mail app question. Its just listed as other on my Android. Its a red icon with a white envelope inside. Its been working fine for a couple of years, thought the jammed email might have been the problem.
Message 9 of 11
Hi
I did send a quick reply but can't see it so you may not have either.
I had only done self tests to my own account on my laptop. Its working fine for other recipients so I'm happy to leave it at that as I can't think of anything else to try. Many thanks for your help.
Message 10 of 11
If you are not receiving emails from your own email address try logging onto your account via a web browser and add your email address to your "safe senders" list. You can find the list by logging onto your email account and clicking on your username at the top right hand side then going to "mail" then "safe senders"
