Message 31 of 33
Re: Overhead Lines
You would need to contact Openreach who own and manage the network.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 32 of 33
Re: Overhead Lines
I doubt they'd answer such a question. No doubt a contracter will arrive one day and just start putting up a dropwire.
Anonymous
Not applicable
Message 33 of 33
Re: Overhead Lines
@Larmanim
"Openreach Limited is a company wholly owned by BT Group plc - yes, it DOES exist."
I assume that you are referring to the discussion on Page 1 of this thread?
You are correct that Openreach is wholly owned by BT Group PLC.
However, there is no such company as "BT Openreach", and Openreach never refer to themselves as such, (officially).
