Message 11 of 15
Re: Parental controls wont turn off
Hi @DavidGoff I'm really sorry about that, I can see my colleague DavidM has been helping you but due to unforeseen circumstances he couldn't work today. We'll get back to you this afternoon.
Neil
Message 12 of 15
Neil, I appreciate you taking the time to reply. You can appreciate it is frustrating to be kept in the dark.
Message 13 of 15
Hi
Did this get sorted? I have the same problem and have tried all the suggestions here.
Message 14 of 15
Yes, eventually we worked out that my number had been switched with someone else's who had the controls set up. I only realised when I called my home phone and heard someone else's answer machine. A long shot but worth a try.
Message 15 of 15
having not worked for a week, I merely called my own phone number then tried again and it was sorted. Maybe a coincidence but thanks for your tip.
