Message 1 of 6
Phone off Hook
My elderly parents constantly leave their phone of the hook. I  see there an alarm, contraption or similar that can notify them.
5 REPLIES 5
Message 2 of 6
Re: Phone off Hook
If they are with BT, then there would be a loud siren sound sent out to the phone for a few minutes, and they should hear it. I am not sure what other providers do.
Message 3 of 6
Re: Phone off Hook
@Cam3 I presume it's a cordless phone your parents use? It's much easier to forget to hang up when you have to press a button on the handset. I've seen corded phones being recommended in this instance as you have to set the phone back down to hang up.
https://www.bt.com/help/here-for-you
Neil
Message 4 of 6
Re: Phone off Hook
What happens is that one of them speaks to me from their (corded) phone and then passes me over to the other person who is on on another phone and doesn’t put the phone down thinking the other will be cut off,  wanders off and forgets all about it!
Message 5 of 6
Re: Phone off Hook
Hi @Cam3 thanks for clarifying, there are amplified phones on the market that may be louder so that your parents can hear the off the hook howler (siren tone) better than on a conventional phone.
Would removing one of the phones from the set-up help? I appreciate that it may not be an option but it would stop this scenario from happening if they both used the same handset.
Neil
Message 6 of 6
Re: Phone off Hook
