Message 1 of 14
Poor second line install
Yesterday i had a second line installed just for fibre 1 broadband
BT had quoted 16Mb dowload , but i get 25Mb with Sky and my neighbours get 23Mb,
This install was done by a sub contractor not Openreach, i had concerns about the line the engineer was going to use and had mentioned this to him , 20 min later he had gone .
Hub powers up and goes blue , i have an appalling  download speed of 11Mps and up 0.8Mps  The engineer has also made my primary line incur severe  errored second faults which has been up to this point stable.
contact BT and they say i have a fault on the new line . they arrange for an engineer to come out today 13th 1pm -6pm , i get a call at 11.15 to say he is at my house , i popped to see him he confirms a fault.
I  had no notification of the fault being repaired & the the fault tracker said the engineer had completed his job, the speed was worse with 9mpb down and up 0.4.
At 7pm today i have no broadband on my new second line and a poor connection on  Primary Sky line.
BT has arranged for an engineer to come out Monday , which would be 5 days after installation
Do i need to contact Sky to check my other line, which has been  upset by the new BT installation ?
 I have 10day of statistics from my modem to show the errors have started in the last 18 hours .
Where do i go from here and what advice can people give me ?
dbigger
13 REPLIES 13
Message 2 of 14
Re: Poor second line install
Enter your BT phone number and post results. Remember delete number. https://www.broadbandchecker.btwholesale.com/#/ADSL
Check lines for noise dial 17070 option 2 should be silent and best with corded phone
Message 3 of 14
Here we go , broadband only line so no 17070Screenshot at 2021-05-13 22-38-00.png
Message 4 of 14
Can you post hub stats from hub manager then advanced settings then technical log information.
You must have a phone line just no phone package as you need the line to get broadband
Message 5 of 14
Hub stats
Screenshot at 2021-05-14 10-50-35.pngScreenshot at 2021-05-14 10-48-24.pngScreenshot at 2021-05-14 10-45-53.png
Message 6 of 14
Just to note it is connected to the master socket , i have tried a different faceplate and cable
Message 7 of 14
the hub stats don't show any internet connection or dsl connection time
there should also be max data rate, noise margin,attenuation etc
Message 8 of 14
These are the statistics from Sky line showing fault accumulations before and after installation of my BT second line
Screenshot at 2021-05-14 11-13-47.pngScreenshot at 2021-05-14 11-13-28.pngof line faults
Message 9 of 14
Yes that's correct , i have no broadband, the original post i stated it went down at 7pm yesterday evening
Message 10 of 14
are you able to connect hub to the test socket with a filter and see if that makes any difference?  is there a dialtone?
