Message 1 of 4
Smart Hub keeps dropping connection
Hi. For the last few days, my hub has kept dropping the connection. I'm trying to work out whether the problem lies with my wiring or is outside the home. I have temporarily moved the hub to connect it to the master socket. Its been a few hours now and the connection hasn't dropped yet (but its gone 5 or 6 hours before and then dropped out every 15 minutes for a couple of hours).
Is there anything in tech log to suggest a problem or do these look normal (I have no idea).
Product name:
BT Hub 6A
Firmware version:
SG4B1000E020
Firmware updated:
21-Dec-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
0 Days, 4 Hours 41 Minutes 40 Seconds
Data rate:
15.00 Mbps / 66.99 Mbps
Maximum data rate:
21612 / 91564
Noise margin:
9.3 dB / 7.4 dB
Line attenuation:
22.2 dB
Signal attenuation:
13.1 dB / 22.2 dB
Thanks for any help, suggestions
3 REPLIES 3
Message 2 of 4
Re: Smart Hub keeps dropping connection
I would have expected your connection to be 80mb not 67mb suggesting there is a problem which is causing the drops in connection.
Try quiet line test. Dial 17070 option 2 should be silent and best from test socket with corded phone
Message 3 of 4
Thanks for the reply. Only got a cordless phone but I’ll try that in the morning and see what happens.
I assume that suggests a problem outside my house rather than with my master socket?
cheers
Message 4 of 4
If you get noise on quiet line test using test socket then problem is outside your home
