Message 1 of 3
Port Forwarding
Hi,
Using the Smart Hut 2 and trying to setup port fowarding.
1) I setup a rule to say that port 9998 needs to forward to IP 192.168.1.x on port 8155.
2) I can telnet from within my network to 192.168.1.x 8155
3) My BT public IP is 86.138.57.92
I can't telnet to 86.138.57.92 9998 from a machine outside my own network.
I was on the phone for one hour with BT with zero progress. All they did was "test the line". Noone there wants to talk about IPs and they told me I wasn't within range?????
When I traceroute 86.138.57.92 it doesn't seem to send me back to that IP. Normal?
How can I make sure that I am even reaching the router? I am not even sure I am reaching the router.
Any one got any idea on how to troubleshoot this next? BT was totally unable to help. "Not many customer use port forwarding they say". I just need it to access my alarm 🙂
Thank you
2 REPLIES 2
Message 2 of 3
Re: Port Forwarding
You cannot run a tracert to a hub from outside your local network as BT Hubs are configured to respond to ICMP requests and this cannot be changed.
You need a third party router to be able to do that.
Message 3 of 3
Re: Port Forwarding
Try turning off UPnP in case it is causing a confliction.
Does Shields Up show the port as open?
