Message 11 of 21
Re: Property address classified as Silver
@ChrisDavies wrote:
Hi there. I just tried that process and when it came to adding my postcode the house number didn't appear in the main list but at the very bottom. The response back was that they would check what services were available at that address and get back to me within 28 days. I think it may have something to do with my address not appearing in the Open Reach database possibly.
Who came back  with that response, was it just automatic?
Message 12 of 21
Yes - auto reply 😫
Message 13 of 21
@ChrisDavies
does the property as a new build have an ONT as I asked originally?  if so no point is getting landline as you would just contact FTTP Team and probably get digital voice
Message 14 of 21
Thanks for reply. Do you have contact details for the FTTP team?
Message 15 of 21
@ChrisDavies wrote:
Yes - auto reply 😫
Then that would have been from BT Retail, if you used that form.
In practice, it should take less than 28 days because BT Retail would pass the request to Openreach quite quickly, and Openreach would check their network records.
The fact that its a silver address, would indicate there is existing infrastructure, and it just needs a routing added to the database.
Message 16 of 21
@ChrisDavies
no point in contacting FTTP team if you do not have an ONT in the property - you need to check first
Message 17 of 21
Message 18 of 21
then you need to phone FTTP Team 08005874787 and see if they can help   there should be a number on the ONT which you need when you phone
Message 19 of 21
Will give that a try. Thanks
Message 20 of 21
 Is this the number I should quote?
