Message 51 of 90
Re: Download speed has been reduced
a dull hum is normal on cordless phone anything else can be a problem  see if stays stable now faceplate clipped securely back in place but if not may need phone engineer for line hiss
Message 52 of 90
Hi,
Thanks, I’ll keep you posted
Message 53 of 90
@Ianf3Does it remain stable if you leave it connected to the test socket?
Message 54 of 90
Hi
well I’d have no landline to take calls if I tried that over 24hrs, only broadband, but if it persists I’ll try it .
it’s dropping about once a day at the moment.
ian
Message 55 of 90
Of course you would, you plug the hub and phone into the filter.
Message 56 of 90
I didn’t realise there was a socket behind the faceplate for this
Message 57 of 90
So the filter is in the faceplate?
or are there 2 sockets underneath, mine only has the test socket?
Message 58 of 90
The face place has 2 outlets - dsl and phone- and is filtered
the test socket is not filtered so you need to use a filter and then you can connect both hub and phone then leave and see if that helps stability
Message 59 of 90
Hi
ive only adsli filters in a cupboard somewhere, will they do?
Message 60 of 90
Yes.
