Message 11 of 20
Re: Is my broadband fibre 2 speed artificially capped or banded
what about max attainable?
Message 12 of 20
58 on the SmartHub2 log but this is still below the Openreach website guidance and surely BT wouldn’t now be offering a 62 speed fast guarantee unless this was attainable
Message 13 of 20
Hi
I have attached a copy of the SmartHub 2 log in the test socket if it assists you. BTW I have no need for any of the other sockets in the house so happy to keep using test socket if there is a way to tidy it up and make that possible?
Product nameBT Smart Hub 2
Serial number+091298+2125026465
Fireware versionv0.30.01.08093-BT (Mon Aug  9 20:01:14 2021)
Board versionR01
GUI version1.74 12_11_2020
DSL uptime0 days 0 Hours 7 Mins 59 Secs
Data rate19.2 Mbps / 47.7 Mbps
Maximum Data rate19.0 Mbps / 57.4 Mbps
Noise margin6.0/6.3
Line attenuation5.5/16.8
Signal attenuation5.6/16.0
VLAN id101
Upstream error controlOff
Downstream error controlOff
Data sent / received71.1 MB Uploaded / 44.3 MB Downloaded
Broadband username[email protected]
BT Wi-FiActive
2.4 GHz wireless network nameBT-SWCMPN
2.4 GHz wireless channelSmart (Channel6)
5 GHz wireless network nameBT-SWCMPN
5 GHz wireless channelSmart (Channel36)
Wireless SecurityWPA2 (Recommanded)
Wireless modeMode 1
FirewallOn
MAC address70:97:41:87:3B:7C
Software variant-
Boot loader0.1.7-BT (Thu Nov 30 09:45:22 2017)
Many thanks
Chris
Message 14 of 20
G.Inp is enabled on your cab and takes about 10 days to kick in giving you a speed boost.
Message 15 of 20
So I only need to wait and I should see an improvement in line with what BT website now offers for same package?
Message 16 of 20
Wait for G.Inp and 3dB noise margin to kick in and post back new stats after a couple of weeks.
Its possible that the reason your speed is much slower than the checker would suggest is that you have an aluminium cable rather than copper.
Message 17 of 20
Thank you! I guess, I will wait and see
Message 18 of 20
Hi
My stats do not appear to be improving and some of them to my untrained eye look to be worse. Any ideas?
Thank you!
Board versionR01
DSL uptime2 days 22 Hours 46 Mins 43 Secs
Data rate17.9 Mbps / 47.9 Mbps
Maximum Data rate17.7 Mbps / 48.3 Mbps
Noise margin6.0/6.3
Line attenuation5.5/16.9
Signal attenuation5.6/16.1
VLAN id101
Data sent / received2.1 GB Uploaded / 2.1 GB Downloaded
BT Wi-FiActive
2.4 GHz wireless channelSmart (Channel1)
Wireless modeMode 1
FirewallOn
Software variant-
Message 19 of 20
your stats show your hub dropped internet connection just short of 3 days ago was that a manual reset or loss of internet?  G.INP mention needs at least 10 days stable connection before you will see any benefit
is there any noise on landline that could be causing connection problem?
Message 20 of 20
Thank you for your quick response. Manual disconnection as we are in the process of decorating. I will do my best to keep the router plugged in for longer!
