Message 1 of 3
Re: Outgoing email rejected as likely spam/malware/phishing
I've just started to get this on my BT mail account.  I'm running it via 'mail' on a Mac.  All was well till a couple of weeks ago, and now it's a nightmare to edit nearly every email to get rid of links, email addresses etc till it will send.
I've no idea what's changed - nothing really..... tried sending using iCloud address and it worked, so it's definitely BT.... no idea what I can change.  I don't use a VPN.
Any ideas anyone......
2 REPLIES 2
Message 2 of 3
Hi @Osdog, I moved your post to create your own thread as the previous one was a few months old. I'm sorry that you are getting this problem. I've sent you a Private Message so you can get in touch with the Mod team and we'll be happy to help you with this.
Cheers
John
Message 3 of 3
Hi @Osdog, thanks for your PM earlier, and thanks for confirming that this fault has now been fixed for you.
cheers
John
