Message 11 of 25
Re: Replace home hub with new router or by a managed switch
Normally in the region of 50mbps download I think.
There is the fibre cabinet in the village... I'd done a bit of research on that as i was toying with replacing the hub with a HG612 and separate router... if that helps?
Message 12 of 25
Yes, that is FTTC. So you need a VDSL modem router
Message 13 of 25
HG612 seems to be something recommended on many a forum or equivalent draytec... I think I like the idea of a separate modem and router.
Am I barking up the right tree?
Message 14 of 25
Entirely up to you if you prefer separate modem and router. The HG612 is getting a bit long in the tooth now but still widely used when separate devices are preferred.
Message 15 of 25
Any alternatives I ought to be considering?
Message 16 of 25
Not really for a standalone modem. The Draytek Vigor 130 and 166 seem to get mixed reports.
For a combined unit, have a look at the TP Link and Asus ranges.
Message 17 of 25
Great thanks 👍
Message 18 of 25
I've got a HG612  en route, could you tell me if this would be a suitable router please...
Message 19 of 25
You need to delete the link as it is against forum rules to link to e-commerce sites.
That would be a suitable router except it doesn't support Bt's implementation of IPv6 unless Netgear have updated their firmware to do so.
Message 20 of 25
I moved to a modem (old ECI) and a DECO M5 mesh system (no router).  I was nervous about it but it has transformed my broadband experience.
