Message 1 of 4
Replacement Modem & Router for VSDL NOT TP link !
Hello community!
I'm looking to replace my homehub router (Version 5, Type A) with a 'better' modem and router combination. I posted before and had a TP link archer recommended, but it started getting serious dropouts so I sent it back. (Wasn't a broadcom chipset, issue with archer widely reported in TO link forums).
If any community members have replaced their homehub with a single unit (due to plugs and clutter I want a combined solution rather than seperate modem and router).  That's not from TP link I'd love to hear their experiences.
Budget is up to £150 (ideally less!). Needs to be able to use 2.4 and 5 GHz bands and have decent enough capabilities for up to 30 simultaneously connected devices. House is medium sized , 3 bed new build so doesn't need to be able to beam through solid brick!
Thanks!!!
James
3 REPLIES 3
Message 2 of 4
Re: Replacement Modem & Router for VSDL NOT TP link !
UPDATE: whilst searching for alternatives I have seen that the Smart Hub 2 is available from the popular online retailer that sells everything from A to Z... Price is as round £50. Is the smart hub 2 leaps and bounds better than the HomeHub 5? If so it may be the solution.
James
Message 3 of 4
Easy answer is 'no'. It also causes some customer problems as you cannot split the 2.4/5ghz networks
Message 4 of 4
@JamesD1
I use an Asus DSL-AC68U and have done for about 6 years now. Mine has been superb and it's within your budget and firmware still supported.
