Anonymous
Not applicable
Message 11 of 57
Re: Router Upgrade from BT SmartHub 2 to a different one
Hi @gg30340,
Thanks for your reply 😊.
Oh right I did put links to re-direct you to Amazon UK website, but I didn't know about post links on the BT Community now I do thanks to @NeilO
🤣 anyway that TP-Link one is a VDSL modem / router, I'll PM you the links if you want me too?
Forgot to also add that I'm after a router that then signal all across my house, my home isn't huge mansion or anything it's just a 3 bedroom house council house I do not want boosters. The house is only built in the 1950's any I want a VDSL router that excellent for signal.
@TimCurtis thanks for the advice 😁 like what I was saying to @gg30340 I'm basically after a router that can pretty much do everything with a perfect signal etc.
@Keith_Beddoe that's the first router that I was looking too buy, yes I do want dual-band wireless. Also want IPv6 as-well Keith mate 🙂.
Right I'll tell you what @Keith_Beddoe@gg30340 & @TimCurtis I want the perfect VDSL router to replace my current one (BT SmartHub 2) I want any of you 3 and including the rest of the BT Community too comment back I don't mind which brand. Like I said I'm willing to spend around from £50 - £200 (no more than £200)
Kind regards,
DanTMan64
Sent from my PC
__________________________________________________________
PC Specs -
CPU: AMD Ryzen 7 2700X
RAM: Corsair Vengeance PRO 16GB RGB
GPU: NVIDIA GeForce GTX 1070 Founders Edition
M.2 Drive: Corsair Force MP510 240GB
HDD: Seagate Barracuda 1TB 7200RPM
Motherboard: ASUS ROG Strix B450-F Gaming
PSU: Corsair TX650M
Keyboard: Corsair K55 RGB
Mouse: Corsair IRONCLAW FPS Gaming Mouse
OS: Windows 10 Pro: 20H2, OS build - 19042.630
Intel 1GB Ethernet Port on PC
Smartphone: Samsung Galaxy S20 Ultra 5G
Anti-virus: PC protected with BT Virus Protect
Products with BT: BT Fibre 2 (Unlimited) with Landline
Router: BT SmartHub 2 (Will be changing to a third-party one soon)
Router sync speeds from exchange to my router:
Upload - 66.698mbps
Download - 20mbps
If you like my post or if it helped you, please thumbs up & click on 'kudos' button. If your problem is solved by my post please click 'Mark as Accepted Solution' button 🤗.
Anonymous
Not applicable
Message 12 of 57
Hi again BT Community 👋,
Forgot to mention that it HAS to be a VDSL port router, I don't want to use the BT SmartHub 2 no more I want to change it too a third-party one 👍.
Kind regards,
DanTMan64
Sent from my PC
PC Specs -
PSU: Corsair TX650M
Upload - 66.698mbps
Download - 20mbps
Message 13 of 57
@Anonymous
I'm certainlly happy to recommend the Asus DSL-AC68U which I've used for many years now & has been rock solid. It like many other third party modem/routers doesn't support G.Fast (UltraFast) so bear that in mind.
It's still available for less than £140 from atleast a couple of reputable vendors.
BTW I do wish you'd use a smaller , sensible font like 99.99% of other community members, so much easier to read especially on small screens.
Message 14 of 57
@TimCurtis wrote:
@Anonymous
Indeed, could you preferably please use the forum default font as your posts are very difficult to read
Anonymous
Not applicable
Message 15 of 57
Hello @TimCurtis,
Thank you I'll have a look on Amazon, Currys | PC World & other retailer's too look for a deal etc. What about the TP-Link is that one no good or something?
I use this font and colour because I have eye problems, my PC is setup to see big text better for my eye and my S20 Ultra 5G Smartphone is set to big text. I do hope you understand. I barely can see the small font that you lot all use I'm sorry 😥 😭 😢.
@licquorice Please look up above, I've explained myself.
Kind regards,
DanTMan64
Sent from my PC
PC Specs -
PSU: Corsair TX650M
Monitor: Dell 75Hz SE2417HGX
Upload - 66.698mbps
Download - 20mbps
If you like my post or if it helped you, please thumbs up & click on Kudos button.jpg button. If your problem is solved by my post please click MaAS button.jpg button 🤗.
Message 16 of 57
For £150 I installed a 3 disc Deco M5 mesh, Wi-Fi absolutely everywhere in a large, stone house.  I no longer use a HH - just the BT modem I was given years ago.  I would recommend the mesh method very strongly.
Anonymous
Not applicable
Message 17 of 57
Hello @gspearson,
I am thankful your comment 🤗. But I ain't looking for Whole-Home Discs etc, I'm just after a third-party VDSL modem / router.
Thank you 😊!
Kind regards,
DanTMan64
Sent from my PC
PC Specs -
PSU: Corsair TX650M
Router sync speeds from the local Cabinet to my router:
Upload - 66.698mbps
Download - 20mbps
If you like my post or if it helped you, please thumbs up & click on Kudos button.jpg button. If your problem is solved by my post please click MaAS button.jpg button ‌‌.
Message 18 of 57
I understand that - I went through all the complicate  solutions first and spent a decent amount of money. The best value was the Deco M5 system - the BT mesh may be just as good/better but the deal seemed complicated and now there are various incomprehensible versions, black, white, owned, rented, and finally a "service".  The mesh idea is that each point talks to the other, so now I don't need to know what wi-fi I have in each room - it is just everywhere, mounds of it, same id, same password.
Anonymous
Not applicable
Message 19 of 57
Hello again @gspearson,
I can't thank you any more for your kind speedy reply 😁. I also already know about MESH network as my Sky Q Minibox MESH's back to the Sky Q Mainbox which is in my living room. Once again I don't want MESH or Discs in my house, I am just after a VDSL modem / router yes I've not find one yet I still undecided on-going wait a reply back from other third-party users etc.
Kind regards,
DanTMan64
Sent from my PC
PC Specs -
PSU: Corsair TX650M
Upload - 66.698mbps
Download - 20mbps
Message 20 of 57
@Anonymous  Sorry to hear about your eyesight problem and can understand now your reasoning behind the font.
However, could I please ask that you do something about your huge sig, its not really appropriate for this forum  and is doubly intrusive due to the font. It is not actually displaying correctly as a sig either, it displays regardless of whether one configures the forum not to display sigs or not.
