Anonymous
Not applicable
Message 21 of 57
Re: Router Upgrade from BT SmartHub 2 to a different one
Hello again @licquorice,
This is the lowest I'm going with my font and colour is this better for you now. Please have a look at Signature I've shorted it down. I cannot believe how small this text is 😮 it's hurting my eye right now 🤔.
Kind regards,
DanTMan64
Sent from my PC
__________________________________________________________
Products with BT: BT Fibre 2 (Unlimited) with Landline
Router: BT SmartHub 2 (Will be changing to a third-party one soon)
Router sync speeds from the local Cabinet to my router:
Upload - 66.698mbps
Download - 20mbps
If you like my post or if it helped you, please thumbs up & click on Kudos button.jpgbutton. If your problem is solved by my post please click MaAS button.jpg button ‌‌.
Message 22 of 57
I don't know why you are keeping the signature including you setup as does not help anyone  your connection speeds are wrong way round
Message 23 of 57
Sorry, but I have to agree with @imjolly , the signature is pretty pointless. I know some forums seem to encourage users to put that sort of information in sigs, but this isn't one of them.
To be honest, it would be preferable for you to use a font that you are comfortable with and no sig.
Anonymous
Not applicable
Message 24 of 57
Hello @imjolly,
I like to show people what products that I've got with BT! Is their a law or something by doing this Signature? Also thank you 🤣 I've just noticed that.
Kind regards,
DanTMan64
Sent from my PC
Download - 66.698mbps
Upload - 20mbps
If you like my post or if it helped you, please thumbs up & click on Kudos button.jpg button. If your problem is solved by my post please click MaAS button.jpg button ‌‌.
Message 25 of 57
@Anonymous
no law just pads out all you posts with unnecessary information
Anonymous
Not applicable
Message 26 of 57
Hello again @imjolly,
OK 🤗 now can you please help me with VDSL modem / routers?
Kind regards,
DanTMan64
Upload - 20mbps
If you like my post or if it helped you, please thumbs up & click on Kudos button.jpg button. If your problem is solved by my post please click MaAS button.jpg button 🤗‌‌.
Message 27 of 57
Regarding the signature.
The guidelines are here:
Signatures - Keep your signatures short.  You may sign your posts with information about yourself, which may include things like a quote from a favourite author, for example.
BT Community User Guidelines - BT Community
Personally I think that they should be done away with but if you are going to use one you should use the correct method of displaying one and that is by using the "signature" section in your profile.
You can do that by clicking on your username then going to "my settings"  > personal information > signature. By doing that it allows the forum members who do not wish to see signatures the ability to select the setting in their profile to turn them off so that they are not shown.
Message 28 of 57
I think it would help people offer their best advice if you explained what problem you are trying to solve; for example, in what way does the BT product not suit your needs?  I'm a licensed radio amateur but even with the qualifications needed to hold such a licence, I do need to come here from time to time to resolve issues.
Geoff
Anonymous
Not applicable
Message 29 of 57
Hello BT Community 👋,
Please take a look down below, I've uploaded some Photos of the VDSL router's that I like the look of but haven't decided which one to buy:
TP-Link AC1200 VDSL modem / router.
ASUS DSL-AC68U VDSL modem / router.
ASUS DSL-AC55U AC1200 VDSL modem / router.
 TP-Link AC2800 Dual Band VDSL modem / router.
NETGEAR D7000-200UKS VDSL modem / router.
All the images are from Amazon UK, I'm after a VDSL router that'll also do IPv6 as-well and which one would be perfect for signal also 🙂.
Kind regards,
DanTMan64
Upload - 20mbps
If you like my post or if it helped you, please thumbs up & click on Kudos button.jpgbutton. If your problem is solved by my post please click MaAS button.jpg button 🤗‌‌.
Message 30 of 57
Apart from avoiding the Netgears due to lack of IPv6, they will all be suitable. Only you know what WiFi speed you need and whether it is worth paying extra for the extra speed bearing in mind unless you are using the WiFi purely within your LAN, the governing speed will be the speed of your broadband connection.
