Message 41 of 57
Re: Router Upgrade from BT SmartHub 2 to a different one
But as all you want is a change and nothing specific then they are suitable for your purpose. If in doubt just put name in hat and draw one
Anonymous
Not applicable
Message 42 of 57
Hello again @imjolly,
LOL 🤣! Anyway, well other 4 VDSL modems / routers work with BT IPv6 & will they give a perfect signal around my home or not?
Kind regards,
DanTMan64
Message 43 of 57
Kind regards,
DanTMan64
There is no way to tell if you will get a perfect wifi signal all around your home
you need to 'bite the bullet' and make your choice
Message 44 of 57
@Anonymous See message 13
Anonymous
Not applicable
Message 45 of 57
OK I'm do some YouTubing and stuff 😂!
@licquorice OK. I check it out & let you all know what I've chosen.
Kind regards,
DanTMan64
Anonymous
Not applicable
Message 46 of 57
Hello all at the BT Community,
I'm still undecided on which VDSL router to go for 🤔. Also I had too work out everything and gotta change my budget spending which is now £50 - £145.
Kind regards,
DanTMan64
Anonymous
Not applicable
Message 47 of 57
Hello again all 👋,
Thought I'd let you all know that I've decided to go with the ASUS DSL-AC68U, but if I cannot get the ASUS DSL-AC68U I will get the NETGEAR D7000-200UKS.
Kind regards,
DanTMan64
Message 48 of 57
@Anonymous
If you want IPV6 then DON'T get the netgear.
My Asus DSL-AC68U gives a very good wifi signal all over my property, that's all I can say.
I know that the TP-Link devices are well thought of and one of them would be my choice after the Asus.
Anonymous
Not applicable
Message 49 of 57
Hello @TimCurtis,
Good afternoon to you bud 😄.
@TimCurtiswrote:
@Anonymous
I keep forgetting about Netgear products and IPv6,
They say that it's 'Ideal for moderate use' I can tell you now that I don't have a moderate use house. I've got a busy home network with Gaming PC, Gaming Console's, Smartphones, Set-up boxes, Smart TV's, CCTV, etc. I just need a high use network one.
My question is can this ASUS DSL-AC68U keep up with a extremely busy household or not?
Kind regards,
DanTMan64
Message 50 of 57
You are making a mountain out of a molehill.
If you insist on replacing your BT hub just for a change, any of the VDSL Modem/routers you have posted will be more than adequate for your needs.
If you don't want the Netgear one just make up your mind an buy one of the other ones. There is really nothing more that any body can add to what has already been posted.
