Message 11 of 31
Re: Router fault has caused DLM to reduce line speed by 50%. How can I get this reset quickly?
I'm honestly not sure how else to explain the real world drop from 50mbit to 25mbit. This is over an ethernet cable plugged directly into the router. This is also a real world figure that's significantly higher than the router reported line speed.
The only other explanation as far as I can tell is that this router is just delivering a much lower speed. But it's rated for 1gbit and is a fairly high end tp-link router. Unless I've somehow configured the router wrong in a way that would somehow limit speed I'm not sure what else to look into?
Message 12 of 31
Have you still got a BT hub you could connect to see what sync speed that gives?
Message 13 of 31
Sadly not, I actually usually entirely rely on nest wifi throughout my home and my BT home hub died a long time ago so I just replaced the router and moved on.
I'm only currently connected to the router because of this speed issue. Generally the router is just a modem that supplies connection to nest wifi.
Message 14 of 31
All I can suggest is see if you can borrow a BT hub or other router to try. If what the router is reporting is accurate, a DLM reset will do nothing.
Message 15 of 31
I'll see if I can find one somewhere I suppose! I appreciate all of the help.
Does anything here look wrong:
Message 16 of 31
You could try setting DSL Annex type to Annex B to see if that makes any difference.
Message 17 of 31
Sadly only Annex A is available in VDSL mode.
Message 18 of 31
Annex A is correct anyway, just something to try.
Message 19 of 31
The username is normally
[email protected]
Message 20 of 31
Enter your phone number and post results. Delete number when posting
