Message 1 of 4
Slow Broadband Still
I have posted before re slow broadband speed, but no real answers to my question.
When I ring customer services, depending who answers me whether they do anything is pot luck.
I have Fibre 250 with Halo 2 on G fast
A guaranteed speed of 150 Mbits. I get about 146 down and 49 up
I've had Openreach out to check and no line problem detected.
A replacement home hub 2 didn't cure it.
No line noise. All testing done at the test socket.
I tried to add speed test results and broadband availability but it exceeds limits.
Perhaps one of the mods might be able to assist me
Studon
3 REPLIES 3
Message 2 of 4
Re: Slow Broadband Still
Hi @Studon, thanks for posting, the router stats you've posted show your Hub is syncing at 329 Mbps downstream. Are you seeing the slower results when using wireless devices?
Message 3 of 4
Hi Neil
There is no difference in speeds if I use wi fi.
My thoughts are that the problem lies with wherever the download speed is set at the Exchange.
Studon
Message 4 of 4
@Studonwrote:
Hi Neil
If the Hub is synching at 329, then the speed from the exchange to the Hub has not been, shall we say, throttled in any way.
