Message 1 of 11
Slow Broadband in evenings
Hi there
Need help please.
My broadband speed gradually slows down from about 7pm.
I have FTTC and normally get about 65-70Mbps download during the day. Just noticed in the last week or so that the speed gradually drops in the evening. On 14th April the lowest speed I recorded was 29.5Mbps at 22.00 hrs. After that the speed gradually increased. By 23.00 hrs it was at 41.8Mbps. Didn’t do any more checks after 23.00 hrs.
At some time during the night it goes back to normal.
There is no noise on a quiet line test.
I have ran speedtests using the BTW performance tester morning and evening and uploaded the results.
All results are using a wired connection from Smart Hub to a desktop PC.
My next door neighbour is having the same problem.
10 REPLIES 10
Message 2 of 11
Re: Slow Broadband in evenings
Looks possibly like  a hot SVLAN at the exchange. BTWholesale should be aware of it and in the process of resolving.
Message 3 of 11
Thanks for the reply pippincp. Will anybody be checking to see if there are any known issues at the exchange that could be causing the problem?
Message 4 of 11
BTWholesale have automatic monitoring in place which will report congestion.
Message 5 of 11
If no congestion is reported and I still have slow broadband speeds in evening what happens then?
Message 6 of 11
If the cause of your problem is congestion, as seems likely, it could take several weeks to resolve depending on what extra infrastructure is required.
Message 7 of 11
How do I find out if congestion is the problem?
Message 8 of 11
There isn't any way to find out, however you have classic congestion symptoms, unchanging sync speed but low download speed at peak times. The BT helpdesk  won't have access to SVLAN utilisation details.
I will ask if the mods are aware of any hot SVLANS on your exchange.
Message 9 of 11
Hi @trekex9,
Thank you for posting. I'm sorry if you're seeing a low down in the evening. If you send me your details, I'll be able to run a few checks on the line and check the network for congestion.
I have sent you a private message with instructions on how to contact the team.  You can access your messages via the envelope icon at the top right of the screen, or click on this link, Private messages
Thanks,
Paddy
Message 10 of 11
Thanks for the replies licquorice. I have been contacted by PaddyB.
