Message 1 of 3
Smart HUB 2 setup
Hi previously had BT with and openreach box that connected to my BT router. Just moved to Smart HUB 2 box as part of upgrade. Previously grey cable went to the openreach box and an ethernet cable (red) went to the router. On Smart HUB 2 the grey cable goes straight to the Smart HUB 2 box (no red ethernet port on new HUB) is this correct
2 REPLIES 2
Message 2 of 3
Re: Smart HUB 2 setup
Yes, Openreach modem no longer required.
Message 3 of 3
if you have FTTC then there is no need for openreach modem and the cable from master socket now goes direct to the dsl connection on back of SH2 - just disconnect from modem and connect to SH2
