Message 1 of 11
Smart Hub 2 - One PC Dropping Connection
I have an issue that has only made itself apparent in the last 6 months - prior to that everything was fine. I have a Smart Hub 2, various wifi devices,  connected via ethernet to the hub I have a switch sharing the connection to a NAS, PC and laptop.
Issue
  • My PC, and only my PC (keeping in mind other ethernet devices connected, routinely loses connection. It was not always the case.
  • It is only with the Smart Hub the connection drops - Mini Hub, iPhone etc it'll hold the connection all day
  • When ethernet goes, I'm unable to connect via wifi either.
  • I'm on both laptop and PC for work and see that PC drops while the laptop doesn't
What I've tried
  • Turning off smart setup
  • Disabling power management on the network card
  • Updating drivers
  • Flushing DNS etc.
  • Restarting hub
  • Restarting PC (sometimes works - perhaps crucially it sometimes works initially and within a minute or two drops)
  • Removing BitDefender and reverting to standard MS AV/Firewall
  • Trying new smart hub
  • Resetting network
  • Reverting to wifi
  • Troubleshooting ethernet/wifi adapters
If I leave it, eventually the connection will return. If I reset the network, that usually restores the connection but it will drop again.
Here are some of the examples of messages I get when troubleshooting - it's not always the same, and sometimes fixes are made, but mostly not
tinternet1.PNGtinternet3.PNGtinternet4.PNGtinternet5.PNGtinternet6.PNGtinternet7.PNGtinternet8.PNGtinternet9.PNGtinternet10.PNGtinternet11.PNG
Any help is much appreciated, as this is beyond frustrating!
10 REPLIES 10
Message 2 of 11
Re: Smart Hub 2 - One PC Dropping Connection
Try giving the PC a static IP address of 192.168.1.10, subnet mask 255.255.255.0, gateway 192.168.1.254 on the network card.
Message 3 of 11
I've added in the below, but TBH it's still the same. In fact, I've had to tether to my iPhone just to send this reply 😞
Message 4 of 11
Are there any more suggestions for this? Ideally, I'd switch the smarthub out entirely but with the phones now plugged into it, this doesn't seem so straightforward.
Many thanks
Message 5 of 11
Set DNS Server address to  192.168.1.254
Untick IPv6 on the network properties page.
Reset the home hub to factory default. That may affect the phone registration.
https://www.bt.com/help/broadband/how-do-i-reset-my-bt-hub-to-its-factory-settings
Message 6 of 11
"My PC, and only my PC (keeping in mind other ethernet devices connected, routinely loses connection. It was not always the case."
Have you tried a new ethernet cable ?
Message 7 of 11
Both changes made. Issue remains. Back tethered to my iphone 😞
Message 8 of 11
Yep - new cable, different port - even a new switch.
Thanks for the suggestion though as it took a while for my brain to click it could be that.
Message 9 of 11
Have you tried using Google public DNS (8.8.8.8 and 8.8.4.4) or one of the other free public DNS servers
Message 10 of 11
Try the following to perform a full reset of the network settings on your Windows PC:
  • Open Control Panel > Network & Internet > Network and Sharing Centre
  • Click on the name of your internet/WIFI connection
  • Select "internet protocol version 4" and click on "properties" at the bottom.
  • Verify this configuration:
                      o  IP address automatically
                      o  DNS server address automatically
Now reset all the network configurations.
   •   Open a Command Prompt as administrator and enter:
  •  ipconfig /flushdns
  •  ipconfig /registerdns
  •  netsh winsock reset
  •  netsh int ip reset
  •  ipconfig /renew
Reboot the computer.
After it is also worth checking the connection properties are set for
Private rather than Public.
