Message 11 of 13
Re: Smart Hub 2 flashing purple but internet is working
Apologies, I misunderstood. I thought the test socket would be separate, rather than the one behind the faceplate that I plug my filter into.
It's been solid blue all day now, since taking the faceplate off and putting it back on again. A flaky connection does seem likely. Thanks again for your help.
Message 12 of 13
That is quite common, as they often make a poor connection.
Message 13 of 13
Thank you. It's a relief that it appears to be something common and fairly easy to work around, for now.
