Message 1 of 3
Smart Hub & Fiber compatibility
Had full Fibre fitted yesterday to the house but my smart hub 2 is not the correct version thus no broadband. My existing hub is the old Copper version and not full-fibre. I have to wait until the correct hub is sent out in the post which could be days, was told my old broadband would not be disconnected until I was up and running with the new installation. However, within 2 hours it was removed. Can I purchase my own hub to get up and running, if so would anyone know of a good make and model to use?
2 REPLIES 2
Message 2 of 3
Re: Smart Hub & Fiber compatibility
if you have a SH2 then you can go to hub manager then advanced settings broadband and there is a switch to turn on FTTP mode so one of the LAN connections becomes WAN
Message 3 of 3
Thank you so much, I have wasted a day and a half on the phone to BT trying to get a new hub sent out. It works perfectly now. can thank you enough.
