Message 1 of 5
Smart hub 2 updates everynight
Hi, my hub is updating every night and my speeds keep dropping. I live an area where 35mb is the fastest i can get but every night it is getting slower and slower currently sat on 25mb. Recently had engineers out to fix line issues (had 7 over last 2 months). Had a new hub and had multiple line tests. Had a dlm reset a month ago. Really just want a fix to this problem
4 REPLIES 4
Message 2 of 5
Re: Smart hub 2 updates everynight
Hi @luigicosta I'm really sorry to see you're having issues with your broadband speed.
Can you post your Home Hub router stats and we'll take a look?
You'll get them by entering 192.168.1.254 in your browser, go to advanced settings then technical log information.
I'd also recommend you do a quiet line test? - dial 17070 option 2 it should be silent.
Neil
Message 3 of 5
 line is quiet
Message 4 of 5
can you enter your phone number and post results  remember delete number before posting
the resets are not your hub updating but probably a noise problem causing hub to drop conenction
have you tried using the test socket with a filter to see if that helps by eliminating your master faceplate and any internal wiring
Message 5 of 5
 sorry for late reply had fam emergency and forgot about this
