Message 11 of 29
Re: Hub 6 Firmware update
The update is automatic and you should not have to do anything
Message 12 of 29
OK thanks for that imjolly 😊👍
Message 13 of 29
Re: Smart hub 6 latest firmware update please?
Mine updated on 3rd March
@ljmwrote:
Thx for reply.Mine is still same as owzat ie March 2020, but as yours has updated i guesss theres still hope for mine!
Message 14 of 29
Mine did the March update and then the other day it updated to SG4B1000E079
Message 15 of 29
Yes, thanks. Mine did the Update in March just after I queried it via this post. Coincidence, I expect.
Message 16 of 29
Hi all, I'm quite new to all this and although I have an IT background, it's not in broadband/networking/wifi etc
I've just taken delivery of a BT Hub 6A which has SG4B1000E020 (April 2020) installed.  I tried an online chat with a rep for BT yesterday to find out when/if an update would be installed and she was adamant that I was on the latest release.
However, from this post it seem that SG4B1000E079 the latest firmware release - is that correct?  How do BT distribute this? I know I can't manually install firmware but I'm not particularly happy to be running on a release that is over two years old.
Message 17 of 29
Connect you hub up and leave it running 24/7 and if it needs an update it will be done automatically from BT.
Message 18 of 29
Hi,
My Home Hub 6 A received a firmware update to SG4B1000E079 on 12 May 22. This was the same day as its 14 day reboot cycle - maybe firmware is pushed as part of this cycle if an update is available ?
Aside: It would be good to know what has been fixed/changed etc ... ;-o
Regards
Stewart
Anonymous
Not applicable
Message 19 of 29
Mine just updated to SG4B1000E079, one change I have noticed is they removed the "Seperate Bands" option under Advanced > Wireless settings, you can still seperate the bands by changing the SSID of the 5G but you no longer have to toggle the seperate bands option for the 5G section on the right to show.
Message 20 of 29
Mine went to SG4B1000E079 on 16th May.
