Message 1 of 5
Smart set up
Can’t find the option for smart set-up
ive found my settings through the browser and been told by bt to try turning off smart set-up to fix a connection problem.
there’s just no option of “smart set up” anywhere.
does anybody know where it can be found? The settings of my bt was found on the browser from my iPhone. Thanks
4 REPLIES 4
Message 2 of 5
Re: Smart set up
enter 192.168.1.254 into address bar then password enter hub manager and smart setup on first home page bottom middle
Turn Off smart setup
Message 3 of 5
Re: Smart set up
Yeah I go through that but there’s no option for smart set up 🤷‍♂️
I’ve seen a screenshot of where it’s meant to be on the homepage but it’s just not on my homepage
Message 4 of 5
Re: Smart set up
Its not visible when accessing the hub from a mobile, you need to use a laptop.
Message 5 of 5
Re: Smart set up
Thanks everyone!
yeah just found this out. I found it on my tablet!
