Message 21 of 29
Re: Speed to hub 70mb speed to devices is 7mb
if @Alistairjcooke1 would post the diagnostic test from btspeedtester will take it from there
Message 22 of 29
Smart setup is already turned off
Message 23 of 29
I ran another diagnostics test with my laptop plugged into the router and got the speeds that I  should be getting around 70mbps but but using the wireless connection directly next to the router it is only around 5mbps and from the powerline adaptors in the house the speed is also less than 10mbps
Message 24 of 29
then connection and hub appear ok  powerline adapters can cause problems with download speed and there are other posts confirming that
Message 25 of 29
I would split the 2.4/5ghz networks and then use wifi analyser on your phone to find the least congested channels to set you hub networks and see if that helps
https://www.bt.com/help/broadband/fix-a-problem/broadband-and-wi-fi/i-want-to-improve-my-wi-fi/how-d...
Message 26 of 29
Can you recommend a good WiFi analyser
Message 27 of 29
I use android and have an app 'wifi analyser' from play store
Message 28 of 29
Again I would strongly suggest that you disconnect all the powerline adapters from the hub. then check the speed,
Message 29 of 29
Hi @Alistairjcooke1 ,
Why are you refusing to post a photo of the results of the https://www.broadbandchecker.btwholesale.com/#/ADSL as requested several times by @imjolly ?
