Message 11 of 29
Re: Speed to hub 70mb speed to devices is 7mb
It is not only at peak times it is throughout the day and I have not streamed or downloaded from any torrents
Message 12 of 29
Are you using pc/laptop connected by Ethernet direct to hub - no powerline adapter
have you turned off smart setup in hub manager?
Message 13 of 29
I am using laptop and i have tried it both directly to hub and through powerline adaptors and have same sort of speeds on everything
who would I tern off smart hub setup?
Message 14 of 29
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
Message 15 of 29
Have you recently upgraded to fibre from adsl? It could be that the profile has been stuck at the adsl speed
Message 16 of 29
@paul_fettes  That would be impossble.
Message 17 of 29
I would disconnect the powerline units and then check the speed I only say this because something similar happened to a relative of mine and it transpired that one of the powerline units had gone faulty and as a result his download speed was crippled,
Message 18 of 29
@pippincp No it’s not, I have had this situation in the last month where a customer had 67M going into the router but only 9M on all devices tried with different routers and devices and all the same. The CP had the line still capped at the adsl speeds and just needed the profile changed
Message 19 of 29
@imjollywrote:
Is the 7mb download speed when you are downloading a file from likes of steam or bit torrent
run btspeedtester and post results. Must be done with Ethernet connection
https://speedtest.btwholesale.com/
Hi @Alistairjcooke1 ,
Can you post the results of the above test requested by @imjolly  remembering to remove your telephone number before posting.
Message 20 of 29
don't remember that case on forum have you got a link?
