Message 1 of 2
Stranded wire rather than solid copper wire
Would I get an internet connection if I connect the incoming internet line to a stranded wire cable (using jelly crimps) and then terminate the stranded wires to the master socket?
1 REPLY 1
Message 2 of 2
Re: Stranded wire rather than solid copper wire
Stranded wire is not suitable for insulation displacement connectors. If it is screw terminals then no problem.
