Message 11 of 32
Re: Sync speed going down
your connection speed has remained constant since your first post but your attainable speed which I think you keep referring to as sync speed will fluctuate up and down and that is normal - mine does daily
Message 12 of 32
Fair enough but why atainable speed couple of months ago was around 55000-54000, 1 week ago it was 49000 and now 45000.
It appears that ip profile is 42500 only
How do i get it increased please.
Message 13 of 32
your profile is based on connection speed not attainable so that has not changed since you posted initially as conenction speed is still the same
have you checked for line noise  dial 17070 option 2  should be silent and best with corded phone using test socket
Message 14 of 32
Thanks for coming back to me, there is no noise on the line.
Message 15 of 32
 Looks like my speed is going down the drain too
Message 16 of 32
That looks like a wireless speed too.
Message 17 of 32
I used to use drytek router and the attainable speed was 77000 with sync speed 55000 - i found an old   scrernshot from jan 2020.
what the hell has happend that an attainable speed is now 45000?
Message 18 of 32
Which master socket do you have?
You say you moved after 12hrs from test socket back to slave socket which dropped up speed as I said  what do you mean by slave socket?
Message 19 of 32
I have nr 2 master socket and cable going around the house to slave socket.
I had my router connected to my slave socket for last couple of years. When i noticed that attainable speed is dropping i moved my router  and connected to the test socket on the master socket to take out of equation wiring issue.
For 12 hours when the router was connected to the test socket the situation didnt improve and it kept going down so i decided to put the router back on my slave socket.
Message 20 of 32
you should not have 2 master socket on the one phone line- only 1 can be the actual master and that is one that is connected to the incoming openreach cable
