Message 1 of 2
UDP Port Blocking
Can someone please confirm if BT block UDP port 9300
I use a service called Rowpro and it requires UDP port 9300 for some of its functionality.
If i tether my machine to my mobile phone the program works as its should do. As soon as i use the BT Infinity connection it doesn't work. I have configured port forwarding on two different routers and it still doesn't work.
Problem is upstream from my router.
any ideas?
thanks
Paul
1 REPLY 1
Message 2 of 2
Re: UDP Port Blocking
I am getting the same issue - did you manage to get this sorted @ppabel1 ?
