Message 11 of 14
Re: Unable to upgrade to Fibre when copper wire is installed at property
Customer support should know about it, they may have to enquire with a supervisor though.
Message 12 of 14
As an update, it says on Open Reach's website "Fibre Checker" that FTTC is available at my property. That is what is making this so confusing.
Open Reach says it is available, I know its available, BT says its available but nobody is able to complete the transaction. It appears to be a deadlock and I have no way to fix it.
Is an ORDI check still needed if it says that FTTC is available on Open Reachs website?
Thanks to everyone as always
Message 13 of 14
The dslchecker result for your phone number dales not show FTTC available and that is what BT use to decide if fibre available or not. You need openreach to update the database so it shows FTTC available then you will be able to order
usually sorted by ORDI request
Message 14 of 14
Okay, I will ask for an ORDI check tomorrow then and keep the thread updated with the progress.
