Message 41 of 47
Re: Unstable WiFi and Ethernet connections suddenly
Hope you're right. Thanks 🙂 As you can imagine I'm pretty paranoid about any activity on the connection/line now.
Message 42 of 47
Our premises has suffered noisy lines for years and Openreach were unable to resolve these. Last year I changed to FTTP for reliability as much as speed reasons. No problems since.
Yes I now pay over double per month but instead of 22mb I get a 500mb reliable connection so I am happy.
Message 43 of 47
"Just get fibre!" Isn't an option, my village doesn't have it.
Thanks for sharing though, I suppose!
Message 44 of 47
Things change. I registered interest in FTTP before it was available in my village via my local enterprise partnership. A year later and it was available. I hope things improve for you.
Message 45 of 47
Thank you, me too.
Unfortunately, you're right. Things changed for the worse, at random it seems.
I would HOPE that waiting for fibre and paying more aren't my only options for having stable net again. 🙂
Message 46 of 47
Presently the cost of FTTP at the same speeds as FTTC are the same. You would only pay more if you went for a higher speed tier than you are already on.
Message 47 of 47
Ah, phew. Bless ya. That last person's message almost drained my last ounce of hope.
Don't have fibre option & can't afford to pay more. Salt in the wound 😞
