Message 1 of 5
Upgrade to Broadband Fibre 250 with Halo 1
Currently have Fibre with BT Halo 1 and would like to know if the upgrade to Fibre 250 is only available with an engineer visit.
FTTP is not available for my property
4 REPLIES 4
Message 2 of 5
Re: Upgrade to Broadband Fibre 250 with Halo 1
If it is you'll be waiting until March 1st at the earliest. Order and see what date they give you.
Message 3 of 5
Can you enter your phone number and post results. Remember delete number
Message 4 of 5
Thank you for the reply. See screenshot below
Message 5 of 5
so the upgrade is to G.FAST and requires the engineer to visit and replace your master socket
